Failed to start listening on a socket.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Attempt to commence listening on a socket failed. Sockets error code = %p1% Socket ID = %p2% Socket type = %p3% Socket family = %p4% Socket protocol = %p5% Application handle = %p6% Stub socket handle = %p7% Local inet address = %p8% Local port = %p9%
| Name | Type |
| p1 | sInt |
| p2 | sInt |
| p3 | xInt32 |
| p4 | xInt32 |
| p5 | xInt32 |
| p6 | uInt32 |
| p7 | uInt32 |
| p8 | VarFmtByteArray |
| p9 | uInt16 |
